# easyexcel核心功能 ## 目录 ### 读 DEMO代码地址:[https://github.com/alibaba/easyexcel/blob/master/src/test/java/com/alibaba/easyexcel/demo/read/ReadTest.java](/src/test/java/com/alibaba/easyexcel/test/demo/read/ReadTest.java) * [最简单的读](#simpleRead) * [指定列的下标或者列名](#indexOrNameRead) * [读多个sheet](#repeatedRead) * [日期、数字或者自定义格式转换](#converterRead) * [多行头](#complexHeaderRead) * [同步的返回](#synchronousRead) * [web中的读](#webRead) ### 写 DEMO代码地址:[https://github.com/alibaba/easyexcel/blob/master/src/test/java/com/alibaba/easyexcel/test/demo/write/WriteTest.java](/src/test/java/com/alibaba/easyexcel/test/demo/write/WriteTest.java) * [最简单的写](#simpleWrite) * [指定写入的列](#indexWrite) * [复杂头写入](#complexHeadWrite) * [重复多次写入](#repeatedWrite) * [日期、数字或者自定义格式转换](#converterWrite) * [图片导出](#imageWrite) * [根据模板写入](#templateWrite) * [列宽、行高](#widthAndHeightWrite) * [自定义样式](#styleWrite) * [合并单元格](#mergeWrite) * [使用table去写入](#tableWrite) * [动态头,实时生成头写入](#dynamicHeadWrite) * [自动列宽(不太精确)](#longestMatchColumnWidthWrite) * [自定义拦截器(下拉,超链接等上面几点都不符合但是要对单元格进行操作的参照这个)](#customHandlerWrite) * [web中的写](#webWrite) ## 读excel样例 ### 最简单的读 ##### excel示例 ![img](img/readme/quickstart/read/demo.png) ##### 对象 ```java @Data public class DemoData { private String string; private Date date; private Double doubleData; } ``` ##### 监听器 ```java public class DemoDataListener extends AnalysisEventListener { private static final Logger LOGGER = LoggerFactory.getLogger(DemoDataListener.class); /** * 每隔5条存储数据库,实际使用中可以3000条,然后清理list ,方便内存回收 */ private static final int BATCH_COUNT = 5; List list = new ArrayList(); @Override public void invoke(DemoData data, AnalysisContext context) { LOGGER.info("解析到一条数据:{}", JSON.toJSONString(data)); list.add(data); if (list.size() >= BATCH_COUNT) { saveData(); list.clear(); } } @Override public void doAfterAllAnalysed(AnalysisContext context) { saveData(); LOGGER.info("所有数据解析完成!"); } /** * 加上存储数据库 */ private void saveData() { LOGGER.info("{}条数据,开始存储数据库!", list.size()); LOGGER.info("存储数据库成功!"); } } ``` ##### 代码 ```java /** * 最简单的读 *
1. 创建excel对应的实体对象 参照{@link DemoData} *
2. 由于默认异步读取excel,所以需要创建excel一行一行的回调监听器,参照{@link DemoDataListener} *
3. 直接读即可 */ @Test public void simpleRead() { // 写法1: String fileName = TestFileUtil.getPath() + "demo" + File.separator + "demo.xlsx"; // 这里 需要指定读用哪个class去读,然后读取第一个sheet 文件流会自动关闭 EasyExcel.read(fileName, DemoData.class, new DemoDataListener()).sheet().doRead(); // 写法2: fileName = TestFileUtil.getPath() + "demo" + File.separator + "demo.xlsx"; ExcelReader excelReader = EasyExcel.read(fileName, DemoData.class, new DemoDataListener()).build(); ReadSheet readSheet = EasyExcel.readSheet(0).build(); excelReader.read(readSheet); // 这里千万别忘记关闭,读的时候会创建临时文件,到时磁盘会崩的 excelReader.finish(); } ``` ### 指定列的下标或者列名 ##### excel示例 参照:[excel示例](#simpleReadExcel) ##### 对象 ```java @Data public class IndexOrNameData { /** * 强制读取第三个 这里不建议 index 和 name 同时用,要么一个对象只用index,要么一个对象只用name去匹配 */ @ExcelProperty(index = 2) private Double doubleData; /** * 用名字去匹配,这里需要注意,如果名字重复,会导致只有一个字段读取到数据 */ @ExcelProperty("字符串标题") private String string; @ExcelProperty("日期标题") private Date date; } ``` ##### 监听器 参照:[监听器](#simpleReadListener) 只是泛型变了而已 ##### 代码 ```java /** * 指定列的下标或者列名 * *
1. 创建excel对应的实体对象,并使用{@link ExcelProperty}注解. 参照{@link IndexOrNameData} *
2. 由于默认异步读取excel,所以需要创建excel一行一行的回调监听器,参照{@link IndexOrNameDataListener} *
3. 直接读即可 */ @Test public void indexOrNameRead() { String fileName = TestFileUtil.getPath() + "demo" + File.separator + "demo.xlsx"; // 这里默认读取第一个sheet EasyExcel.read(fileName, IndexOrNameData.class, new IndexOrNameDataListener()).sheet().doRead(); } ``` ### 读多个sheet ##### excel示例 参照:[excel示例](#simpleReadExcel) ##### 对象 参照:[对象](#simpleReadObject) ##### 监听器 参照:[监听器](#simpleReadListener) ##### 代码 ```java /** * 读多个sheet,这里注意一个sheet不能读取多次,多次读取需要重新读取文件 *
3. 直接读即可 */ @Test public void repeatedRead() { String fileName = TestFileUtil.getPath() + "demo" + File.separator + "demo.xlsx"; ExcelReader excelReader = EasyExcel.read(fileName, DemoData.class, new DemoDataListener()).build(); ReadSheet readSheet1 = EasyExcel.readSheet(0).build(); ReadSheet readSheet2 = EasyExcel.readSheet(1).build(); excelReader.read(readSheet1); excelReader.read(readSheet2); // 这里千万别忘记关闭,读的时候会创建临时文件,到时磁盘会崩的 excelReader.finish(); } ``` ### 日期、数字或者自定义格式转换 ##### excel示例 参照:[excel示例](#simpleReadExcel) ##### 对象 ```java @Data public class ConverterData { /** * 我自定义 转换器,不管数据库传过来什么 。我给他加上“自定义:” */ @ExcelProperty(converter = CustomStringStringConverter.class) private String string; /** * 这里用string 去接日期才能格式化。我想接收年月日格式 */ @DateTimeFormat("yyyy年MM月dd日HH时mm分ss秒") private String date; /** * 我想接收百分比的数字 */ @NumberFormat("#.##%") private String doubleData; } ``` ##### 监听器 参照:[监听器](#simpleReadListener) 只是泛型变了 ##### 自定义转换器 ````java public class CustomStringStringConverter implements Converter { @Override public Class supportJavaTypeKey() { return String.class; } @Override public CellDataTypeEnum supportExcelTypeKey() { return CellDataTypeEnum.STRING; } /** * 这里读的时候会调用 * * @param cellData * NotNull * @param contentProperty * Nullable * @param globalConfiguration * NotNull * @return */ @Override public String convertToJavaData(CellData cellData, ExcelContentProperty contentProperty, GlobalConfiguration globalConfiguration) { return "自定义:" + cellData.getStringValue(); } /** * 这里是写的时候会调用 不用管 * * @param value * NotNull * @param contentProperty * Nullable * @param globalConfiguration * NotNull * @return */ @Override public CellData convertToExcelData(String value, ExcelContentProperty contentProperty, GlobalConfiguration globalConfiguration) { return new CellData(value); } } ```` ##### 代码 ```java /** * 日期、数字或者自定义格式转换 *
* 默认读的转换器{@link DefaultConverterLoader#loadDefaultReadConverter()} *
1. 创建excel对应的实体对象 参照{@link ConverterData}.里面可以使用注解{@link DateTimeFormat}、{@link NumberFormat}或者自定义注解 *
2. 由于默认异步读取excel,所以需要创建excel一行一行的回调监听器,参照{@link ConverterDataListener} *
3. 直接读即可 */ @Test public void converterRead() { String fileName = TestFileUtil.getPath() + "demo" + File.separator + "demo.xlsx"; // 这里 需要指定读用哪个class去读,然后读取第一个sheet 然后千万别忘记 finish EasyExcel.read(fileName, ConverterData.class, new ConverterDataListener()) // 这里注意 我们也可以registerConverter来指定自定义转换器, 但是这个转换变成全局了, 所有java为string,excel为string的都会用这个转换器。 // 如果就想单个字段使用请使用@ExcelProperty 指定converter // .registerConverter(new CustomStringStringConverter()) // 读取sheet .sheet().doRead(); } ``` ### 多行头 ##### excel示例 参照:[excel示例](#simpleReadExcel) ##### 对象 参照:[对象](#simpleReadObject) ##### 监听器 参照:[监听器](#simpleReadListener) ##### 代码 ```java /** * 多行头 * *
3. 设置headRowNumber参数,然后读。 这里要注意headRowNumber如果不指定, 会根据你传入的class的{@link ExcelProperty#value()}里面的表头的数量来决定行数, * 如果不传入class则默认为1.当然你指定了headRowNumber不管是否传入class都是以你传入的为准。 */ @Test public void complexHeaderRead() { String fileName = TestFileUtil.getPath() + "demo" + File.separator + "demo.xlsx"; // 这里 需要指定读用哪个class去读,然后读取第一个sheet 然后千万别忘记 finish EasyExcel.read(fileName, DemoData.class, new DemoDataListener()).sheet() // 这里可以设置1,因为头就是一行。如果多行头,可以设置其他值。不传入也可以,因为默认会根据DemoData 来解析,他没有指定头,也就是默认1行 .headRowNumber(1).doRead(); } ``` ### 同步的返回 ##### excel示例 参照:[excel示例](#simpleReadExcel) ##### 对象 参照:[对象](#simpleReadObject) ##### 代码 ```java /** * 同步的返回,不推荐使用,如果数据量大会把数据放到内存里面 */ @Test public void synchronousRead() { String fileName = TestFileUtil.getPath() + "demo" + File.separator + "demo.xlsx"; // 这里 需要指定读用哪个class去读,然后读取第一个sheet 同步读取会自动finish List list = EasyExcel.read(fileName).head(DemoData.class).sheet().doReadSync(); for (Object obj : list) { DemoData data = (DemoData)obj; LOGGER.info("读取到数据:{}", JSON.toJSONString(data)); } // 这里 也可以不指定class,返回一个list,然后读取第一个sheet 同步读取会自动finish list = EasyExcel.read(fileName).sheet().doReadSync(); for (Object obj : list) { // 返回每条数据的键值对 表示所在的列 和所在列的值 Map data = (Map)obj; LOGGER.info("读取到数据:{}", JSON.toJSONString(data)); } } ``` ### web中的读 ##### 示例代码 DEMO代码地址:[https://github.com/alibaba/easyexcel/blob/master/src/test/java/com/alibaba/easyexcel/test/demo/web/WebTest.java](/src/test/java/com/alibaba/easyexcel/test/demo/web/WebTest.java) ##### excel示例 参照:[excel示例](#simpleReadExcel) ##### 对象 参照:[对象](#simpleReadObject) 只是名字变了 ##### 监听器 参照:[监听器](#simpleReadListener) 只是泛型变了 ##### 代码 ```java /** * 文件上传 *
1. 创建excel对应的实体对象 参照{@link UploadData} *
2. 由于默认异步读取excel,所以需要创建excel一行一行的回调监听器,参照{@link UploadDataListener} *
3. 直接读即可 */ @PostMapping("upload") @ResponseBody public String upload(MultipartFile file) throws IOException { EasyExcel.read(file.getInputStream(), UploadData.class, new UploadDataListener()).sheet().doRead(); return "success"; } ``` ## 写excel样例 ### 通用数据生成 后面不会重复写 ```java private List data() { List list = new ArrayList(); for (int i = 0; i < 10; i++) { DemoData data = new DemoData(); data.setString("字符串" + i); data.setDate(new Date()); data.setDoubleData(0.56); list.add(data); } return list; } ``` ### 最简单的写 ##### excel示例 ![img](img/readme/quickstart/write/simpleWrite.png) ##### 对象 ```java @Data public class DemoData { @ExcelProperty("字符串标题") private String string; @ExcelProperty("日期标题") private Date date; @ExcelProperty("数字标题") private Double doubleData; } ``` ##### 代码 ```java /** * 最简单的写 *
2. 直接写即可 */ @Test public void simpleWrite() { // 写法1 String fileName = TestFileUtil.getPath() + "simpleWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 // 如果这里想使用03 则 传入excelType参数即可 EasyExcel.write(fileName, DemoData.class).sheet("模板").doWrite(data()); // 写法2 fileName = TestFileUtil.getPath() + "simpleWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读 ExcelWriter excelWriter = EasyExcel.write(fileName, DemoData.class).build(); WriteSheet writeSheet = EasyExcel.writerSheet("模板").build(); excelWriter.write(data(), writeSheet); /// 千万别忘记finish 会帮忙关闭流 excelWriter.finish(); } ``` ### 指定写入的列 ##### excel示例 ![img](img/readme/quickstart/write/indexWrite.png) ##### 对象 ```java @Data public class IndexData { @ExcelProperty(value = "字符串标题", index = 0) private String string; @ExcelProperty(value = "日期标题", index = 1) private Date date; /** * 这里设置3 会导致第二列空的 */ @ExcelProperty(value = "数字标题", index = 3) private Double doubleData; } ``` ##### 代码 ```java /** * 指定写入的列 *
1. 创建excel对应的实体对象 参照{@link IndexData} *
2. 使用{@link ExcelProperty}注解指定写入的列 *
3. 直接写即可 */ @Test public void indexWrite() { String fileName = TestFileUtil.getPath() + "indexWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, IndexData.class).sheet("模板").doWrite(data()); } ``` ### 复杂头写入 ##### excel示例 ![img](img/readme/quickstart/write/complexHeadWrite.png) ##### 对象 ```java @Data public class ComplexHeadData { @ExcelProperty({"主标题", "字符串标题"}) private String string; @ExcelProperty({"主标题", "日期标题"}) private Date date; @ExcelProperty({"主标题", "数字标题"}) private Double doubleData; } ``` ##### 代码 ```java /** * 复杂头写入 *
1. 创建excel对应的实体对象 参照{@link ComplexHeadData} *
2. 使用{@link ExcelProperty}注解指定复杂的头 *
3. 直接写即可 */ @Test public void complexHeadWrite() { String fileName = TestFileUtil.getPath() + "complexHeadWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, ComplexHeadData.class).sheet("模板").doWrite(data()); } ``` ### 重复多次写入 ##### excel示例 ![img](img/readme/quickstart/write/repeatedWrite.png) ##### 对象 参照:[对象](#simpleWriteObject) ##### 代码 ```java /** * 重复多次写入 *
3. 直接调用二次写入即可 */ @Test public void repeatedWrite() { String fileName = TestFileUtil.getPath() + "repeatedWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读 ExcelWriter excelWriter = EasyExcel.write(fileName, DemoData.class).build(); WriteSheet writeSheet = EasyExcel.writerSheet("模板").build(); // 第一次写入会创建头 excelWriter.write(data(), writeSheet); // 第二次写入会在上一次写入的最后一行后面写入 excelWriter.write(data(), writeSheet); /// 千万别忘记finish 会帮忙关闭流 excelWriter.finish(); } ``` ### 日期、数字或者自定义格式转换 ##### excel示例 ![img](img/readme/quickstart/write/converterWrite.png) ##### 对象 ```java @Data public class ConverterData { /** * 我想所有的 字符串起前面加上"自定义:"三个字 */ @ExcelProperty(value = "字符串标题", converter = CustomStringStringConverter.class) private String string; /** * 我想写到excel 用年月日的格式 */ @DateTimeFormat("yyyy年MM月dd日HH时mm分ss秒") @ExcelProperty("日期标题") private Date date; /** * 我想写到excel 用百分比表示 */ @NumberFormat("#.##%") @ExcelProperty(value = "数字标题") private Double doubleData; } ``` ##### 代码 ```java /** * 日期、数字或者自定义格式转换 *
1. 创建excel对应的实体对象 参照{@link ConverterData} *
2. 使用{@link ExcelProperty}配合使用注解{@link DateTimeFormat}、{@link NumberFormat}或者自定义注解 *
3. 直接写即可 */ @Test public void converterWrite() { String fileName = TestFileUtil.getPath() + "converterWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, ConverterData.class).sheet("模板").doWrite(data()); } ``` ### 图片导出 ##### excel示例 ![img](img/readme/quickstart/write/imageWrite.png) ##### 对象 ```java @Data @ContentRowHeight(100) @ColumnWidth(100 / 8) public class ImageData { private File file; private InputStream inputStream; /** * 如果string类型 必须指定转换器,string默认转换成string */ @ExcelProperty(converter = StringImageConverter.class) private String string; private byte[] byteArray; } ``` ##### 代码 ```java /** * 图片导出 *
1. 创建excel对应的实体对象 参照{@link ImageData} *
2. 直接写即可 */ @Test public void imageWrite() throws Exception { String fileName = TestFileUtil.getPath() + "imageWrite" + System.currentTimeMillis() + ".xlsx"; // 如果使用流 记得关闭 InputStream inputStream = null; try { List list = new ArrayList(); ImageData imageData = new ImageData(); list.add(imageData); String imagePath = TestFileUtil.getPath() + "converter" + File.separator + "img.jpg"; // 放入四种类型的图片 实际使用只要选一种即可 imageData.setByteArray(FileUtils.readFileToByteArray(new File(imagePath))); imageData.setFile(new File(imagePath)); imageData.setString(imagePath); inputStream = FileUtils.openInputStream(new File(imagePath)); imageData.setInputStream(inputStream); EasyExcel.write(fileName, ImageData.class).sheet().doWrite(list); } finally { if (inputStream != null) { inputStream.close(); } } } ``` ### 根据模板写入 ##### 模板excel示例 参照:[模板excel示例](#simpleReadExcel) ##### excel示例 ![img](img/readme/quickstart/write/templateWrite.png) ##### 对象 参照:[对象](#simpleWriteObject) ##### 代码 ```java /** * 根据模板写入 *
3. 使用withTemplate 读取模板 *
4. 直接写即可 */ @Test public void templateWrite() { String templateFileName = TestFileUtil.getPath() + "demo" + File.separator + "demo.xlsx"; String fileName = TestFileUtil.getPath() + "templateWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, DemoData.class).withTemplate(templateFileName).sheet().doWrite(data()); } ``` ### 列宽、行高 ##### excel示例 ![img](img/readme/quickstart/write/widthAndHeightWrite.png) ##### 对象 ````java @Data @ContentRowHeight(10) @HeadRowHeight(20) @ColumnWidth(25) public class WidthAndHeightData { @ExcelProperty("字符串标题") private String string; @ExcelProperty("日期标题") private Date date; /** * 宽度为50 */ @ColumnWidth(50) @ExcelProperty("数字标题") private Double doubleData; } ```` ##### 代码 ```java /** * 列宽、行高 *
1. 创建excel对应的实体对象 参照{@link WidthAndHeightData} *
2. 使用注解{@link ColumnWidth}、{@link HeadRowHeight}、{@link ContentRowHeight}指定宽度或高度 *
3. 直接写即可 */ @Test public void widthAndHeightWrite() { String fileName = TestFileUtil.getPath() + "widthAndHeightWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, WidthAndHeightData.class).sheet("模板").doWrite(data()); } ``` ### 自定义样式 ##### excel示例 ![img](img/readme/quickstart/write/styleWrite.png) ##### 对象 参照:[对象](#simpleWriteObject) ##### 代码 ```java /** * 自定义样式 *
2. 创建一个style策略 并注册 *
3. 直接写即可 */ @Test public void styleWrite() { String fileName = TestFileUtil.getPath() + "styleWrite" + System.currentTimeMillis() + ".xlsx"; // 头的策略 WriteCellStyle headWriteCellStyle = new WriteCellStyle(); // 背景设置为红色 headWriteCellStyle.setFillForegroundColor(IndexedColors.RED.getIndex()); WriteFont headWriteFont = new WriteFont(); headWriteFont.setFontHeightInPoints((short)20); headWriteCellStyle.setWriteFont(headWriteFont); // 内容的策略 WriteCellStyle contentWriteCellStyle = new WriteCellStyle(); // 这里需要指定 FillPatternType 为FillPatternType.SOLID_FOREGROUND 不然无法显示背景颜色.头默认了 FillPatternType所以可以不指定 contentWriteCellStyle.setFillPatternType(FillPatternType.SOLID_FOREGROUND); // 背景绿色 contentWriteCellStyle.setFillForegroundColor(IndexedColors.GREEN.getIndex()); WriteFont contentWriteFont = new WriteFont(); // 字体大小 contentWriteFont.setFontHeightInPoints((short)20); contentWriteCellStyle.setWriteFont(contentWriteFont); // 这个策略是 头是头的样式 内容是内容的样式 其他的策略可以自己实现 HorizontalCellStyleStrategy horizontalCellStyleStrategy = new HorizontalCellStyleStrategy(headWriteCellStyle, contentWriteCellStyle); // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, DemoData.class).registerWriteHandler(horizontalCellStyleStrategy).sheet("模板") .doWrite(data()); } ``` ### 合并单元格 ##### excel示例 ![img](img/readme/quickstart/write/mergeWrite.png) ##### 对象 参照:[对象](#simpleWriteObject) ##### 代码 ```java /** * 合并单元格 *
2. 创建一个merge策略 并注册 *
3. 直接写即可 */ @Test public void mergeWrite() { String fileName = TestFileUtil.getPath() + "mergeWrite" + System.currentTimeMillis() + ".xlsx"; // 每隔2行会合并 把eachColumn 设置成 3 也就是我们数据的长度,所以就第一列会合并。当然其他合并策略也可以自己写 LoopMergeStrategy loopMergeStrategy = new LoopMergeStrategy(2, 0); // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, DemoData.class).registerWriteHandler(loopMergeStrategy).sheet("模板") .doWrite(data()); } ``` ### 使用table去写入 ##### excel示例 ![img](img/readme/quickstart/write/tableWrite.png) ##### 对象 参照:[对象](#simpleWriteObject) ##### 代码 ```java /** * 使用table去写入 *
2. 然后写入table即可 */ @Test public void tableWrite() { String fileName = TestFileUtil.getPath() + "tableWrite" + System.currentTimeMillis() + ".xlsx"; // 这里直接写多个table的案例了,如果只有一个 也可以直一行代码搞定,参照其他案例 // 这里 需要指定写用哪个class去读 ExcelWriter excelWriter = EasyExcel.write(fileName, DemoData.class).build(); // 把sheet设置为不需要头 不然会输出sheet的头 这样看起来第一个table 就有2个头了 WriteSheet writeSheet = EasyExcel.writerSheet("模板").needHead(Boolean.FALSE).build(); // 这里必须指定需要头,table 会继承sheet的配置,sheet配置了不需要,table 默认也是不需要 WriteTable writeTable0 = EasyExcel.writerTable(0).needHead(Boolean.TRUE).build(); WriteTable writeTable1 = EasyExcel.writerTable(1).needHead(Boolean.TRUE).build(); // 第一次写入会创建头 excelWriter.write(data(), writeSheet, writeTable0); // 第二次写如也会创建头,然后在第一次的后面写入数据 excelWriter.write(data(), writeSheet, writeTable1); /// 千万别忘记finish 会帮忙关闭流 excelWriter.finish(); } ``` ### 动态头,实时生成头写入 ##### excel示例 ![img](img/readme/quickstart/write/dynamicHeadWrite.png) ##### 对象 参照:[对象](#simpleWriteObject) ##### 代码 ```java /** * 动态头,实时生成头写入 *
* 思路是这样子的,先创建List头格式的sheet仅仅写入头,然后通过table 不写入头的方式 去写入数据 * *
2. 然后写入table即可 */ @Test public void dynamicHeadWrite() { String fileName = TestFileUtil.getPath() + "dynamicHeadWrite" + System.currentTimeMillis() + ".xlsx"; // write的时候 不传入 class 在table的时候传入 EasyExcel.write(fileName) // 这里放入动态头 .head(head()).sheet("模板") // table的时候 传入class 并且设置needHead =false .table().head(DemoData.class).needHead(Boolean.FALSE).doWrite(data()); } private List> head() { List> list = new ArrayList>(); List head0 = new ArrayList(); head0.add("字符串" + System.currentTimeMillis()); List head1 = new ArrayList(); head1.add("数字" + System.currentTimeMillis()); List head2 = new ArrayList(); head2.add("日期" + System.currentTimeMillis()); list.add(head0); list.add(head1); list.add(head2); return list; } ``` ### 自动列宽(不太精确) ##### excel示例 ![img](img/readme/quickstart/write/longestMatchColumnWidthWrite.png) ##### 对象 ```java @Data public class LongestMatchColumnWidthData { @ExcelProperty("字符串标题") private String string; @ExcelProperty("日期标题很长日期标题很长日期标题很长很长") private Date date; @ExcelProperty("数字") private Double doubleData; } ``` ##### 代码 ```java /** * 自动列宽(不太精确) *
* 这个目前不是很好用,比如有数字就会导致换行。而且长度也不是刚好和实际长度一致。 所以需要精确到刚好列宽的慎用。 当然也可以自己参照 * {@link LongestMatchColumnWidthStyleStrategy}重新实现. *
* poi 自带{@link SXSSFSheet#autoSizeColumn(int)} 对中文支持也不太好。目前没找到很好的算法。 有的话可以推荐下。 * *
* 1. 创建excel对应的实体对象 参照{@link LongestMatchColumnWidthData} *
* 2. 注册策略{@link LongestMatchColumnWidthStyleStrategy} *
* 3. 直接写即可 */ @Test public void longestMatchColumnWidthWrite() { String fileName = TestFileUtil.getPath() + "longestMatchColumnWidthWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, LongestMatchColumnWidthData.class) .registerWriteHandler(new LongestMatchColumnWidthStyleStrategy()).sheet("模板").doWrite(dataLong()); } private List dataLong() { List list = new ArrayList(); for (int i = 0; i < 10; i++) { LongestMatchColumnWidthData data = new LongestMatchColumnWidthData(); data.setString("测试很长的字符串测试很长的字符串测试很长的字符串" + i); data.setDate(new Date()); data.setDoubleData(1000000000000.0); list.add(data); } return list; } ``` ### 自定义拦截器(上面几点都不符合但是要对单元格进行操作的参照这个) ##### excel示例 ![img](img/readme/quickstart/write/customHandlerWrite.png) ##### 对象 参照:[对象](#simpleWriteObject) ##### 定义拦截器 ````java /** * 自定义拦截器。对第一行第一列的头超链接到:https://github.com/alibaba/easyexcel * * @author Jiaju Zhuang */ public class CustomCellWriteHandler implements CellWriteHandler { private static final Logger LOGGER = LoggerFactory.getLogger(CustomCellWriteHandler.class); @Override public void beforeCellCreate(WriteSheetHolder writeSheetHolder, WriteTableHolder writeTableHolder, Row row, Head head, int relativeRowIndex, boolean isHead) { } @Override public void afterCellCreate(WriteSheetHolder writeSheetHolder, WriteTableHolder writeTableHolder, CellData cellData, Cell cell, Head head, int relativeRowIndex, boolean isHead) { // 这里可以对cell进行任何操作 LOGGER.info("第{}行,第{}列写入完成。", cell.getRowIndex(), cell.getColumnIndex()); if (isHead && cell.getColumnIndex() == 0) { CreationHelper createHelper = writeSheetHolder.getSheet().getWorkbook().getCreationHelper(); Hyperlink hyperlink = createHelper.createHyperlink(HyperlinkType.URL); hyperlink.setAddress("https://github.com/alibaba/easyexcel"); cell.setHyperlink(hyperlink); } } } ```` ````java /** * 自定义拦截器.对第一列第一行和第二行的数据新增下拉框,显示 测试1 测试2 * * @author Jiaju Zhuang */ public class CustomSheetWriteHandler implements SheetWriteHandler { private static final Logger LOGGER = LoggerFactory.getLogger(CustomSheetWriteHandler.class); @Override public void beforeSheetCreate(WriteWorkbookHolder writeWorkbookHolder, WriteSheetHolder writeSheetHolder) { } @Override public void afterSheetCreate(WriteWorkbookHolder writeWorkbookHolder, WriteSheetHolder writeSheetHolder) { LOGGER.info("第{}个Sheet写入成功。", writeSheetHolder.getSheetNo()); // 区间设置 第一列第一行和第二行的数据。由于第一行是头,所以第一、二行的数据实际上是第二三行 CellRangeAddressList cellRangeAddressList = new CellRangeAddressList(1, 2, 0, 0); DataValidationHelper helper = writeSheetHolder.getSheet().getDataValidationHelper(); DataValidationConstraint constraint = helper.createExplicitListConstraint(new String[] {"测试1", "测试2"}); DataValidation dataValidation = helper.createValidation(constraint, cellRangeAddressList); writeSheetHolder.getSheet().addValidationData(dataValidation); } } ```` ##### 代码 ```java /** * 下拉,超链接等自定义拦截器(上面几点都不符合但是要对单元格进行操作的参照这个) *
* demo这里实现2点。1. 对第一行第一列的头超链接到:https://github.com/alibaba/easyexcel 2. 对第一列第一行和第二行的数据新增下拉框,显示 测试1 测试2 *
* 1. 创建excel对应的实体对象 参照{@link DemoData} *
* 2. 注册拦截器 {@link CustomCellWriteHandler} {@link CustomSheetWriteHandler} *
* 2. 直接写即可 */ @Test public void customHandlerWrite() { String fileName = TestFileUtil.getPath() + "customHandlerWrite" + System.currentTimeMillis() + ".xlsx"; // 这里 需要指定写用哪个class去读,然后写到第一个sheet,名字为模板 然后文件流会自动关闭 EasyExcel.write(fileName, DemoData.class).registerWriteHandler(new CustomSheetWriteHandler()) .registerWriteHandler(new CustomCellWriteHandler()).sheet("模板").doWrite(data()); } ``` ### web中的写 ##### 示例代码 DEMO代码地址:[https://github.com/alibaba/easyexcel/blob/master/src/test/java/com/alibaba/easyexcel/test/demo/web/WebTest.java](/src/test/java/com/alibaba/easyexcel/test/demo/web/WebTest.java) ##### 对象 参照:[对象](#simpleWriteObject) 就是名称变了下 ##### 代码 ```java /** * 文件下载 *
1. 创建excel对应的实体对象 参照{@link DownloadData} *
2. 设置返回的 参数 *
3. 直接写,这里注意,finish的时候会自动关闭OutputStream,当然你外面再关闭流问题不大 */ @GetMapping("download") public void download(HttpServletResponse response) throws IOException { response.setContentType("application/vnd.ms-excel"); response.setCharacterEncoding("utf-8"); response.setHeader("Content-disposition", "attachment;filename=demo.xlsx"); EasyExcel.write(response.getOutputStream(), DownloadData.class).sheet("模板").doWrite(data()); } ``` ## 测试数据分析 ![POI usermodel PK easyexcel(Excel 2003).png](http://ata2-img.cn-hangzhou.img-pub.aliyun-inc.com/02c4bfbbab99a649788523d04f84a42f.png) ![POI usermodel PK easyexcel(Excel 2007).png](http://ata2-img.cn-hangzhou.img-pub.aliyun-inc.com/f6a8a19ec959f0eb564e652de523fc9e.png) ![POI usermodel PK easyexcel(Excel 2003) (1).png](http://ata2-img.cn-hangzhou.img-pub.aliyun-inc.com/26888f7ea1cb8dc56db494926544edf7.png) ![POI usermodel PK easyexcel(Excel 2007) (1).png](http://ata2-img.cn-hangzhou.img-pub.aliyun-inc.com/4de1ac95bdfaa4b1870b224af4f4cb75.png) 从上面的性能测试可以看出easyexcel在解析耗时上比poiuserModel模式弱了一些。主要原因是我内部采用了反射做模型字段映射,中间我也加了cache,但感觉这点差距可以接受的。但在内存消耗上差别就比较明显了,easyexcel在后面文件再增大,内存消耗几乎不会增加了。但poi userModel就不一样了,简直就要爆掉了。想想一个excel解析200M,同时有20个人再用估计一台机器就挂了。
